Spb GPRS monitor - problem
Zdravim, ked si nainstalujem SPB GPRS monitor, tak ked dam monitorovat pripojenie, tak sa potom nemozem cez to pripojenie pripojit... Jednoducho mi PDA zamrzne a pomaha iba soft reset...
Nemoze to byt sposobene tym, ze toto pripojenie potrebuje specialny AT prikaz, ktory vo wm6 sa neda kam zadat, tak som ho musel zapisat do registrov?
Dik za odpovede...
Skusal som aj HR PDA a potom som nastavil pripojenie a nainstaloval SPB GPRS monitor a vysledok ten isty...
Dik za odpovede...
V tomto případě by asi bylo lepší dát dotaz do fóra k tomuto softíku přímo na webu výrobce. Dnes už tolik WM 6 zařízení "no-gsm" není, takže ani moc majitelů schopných poradit.
No napisal som na technicku podporu, uvidim kedy odpisu, imho pozeral som dost diskuzii, a nikto nemal s tymto softwarom problem...
Odpovedali da sa povedat ihned:
Moj mail:
[QUOTE]Dear Sir/Madam
I have PPC device - HP iPAQ 210 - not listed in your list of devices.
I connect to the internet via BT phone.
When I connect to the Internet without installed Spb GPRS Monitor, it works....
But, when I connect with Spb GPRS Monitor installed and selected monitoring this connection, whole system stucks and I have to do a soft reset…
Unfortunately my phone requires a special AT command to choose a right APN.
But, Windows mobile 6 classic doesn’t support special AT commands, so I have to insert it to the registry..
Maybe this is the reason…. But I won’t connect to the internet, if I don’t put special AT string…
Yours faithfully
XXXX
Odpoved:
[QUOTE]Dear XXXX,
it seems to be a bug. Unfortunately we do not have this device in the office now to reptoduce the issue on our side. I passed it to our developers for further investigation.
Feel free to contact us if you have any additional questions. You can always refer to this ticket using this link:
http://support.softspb.com/default.asp?......
Best regards,
Spb Software House Support Team
Este ze som si to nekupil, zatial som len skusal demo ;-)
P.S.: Nepozante nejaku inu alternativu k tomuto programu?
EDIT: som nasiel - > Efficasoft GPRS Traffic monitor
A je to dokonca freeware ;)
Moj mail:
Yours faithfully
XXXX
Odpoved:
[QUOTE]Dear XXXX,
Best regards,
