USB konektivita pri RX1.WM6.v1
Zdravim, mam Mio A701 RX1.WM6.v01. Ako uz bolo skor spominane tiez mam problem s konektivitou na USB. Nemozem sa pripojit na PC a tak nemozem urobit ani upgrade. Vite mi niekto poradit ako rozbehat to US pripadne ako urobit upgrade bez USB? D
problem nie je z usb iba s active synclerom a ten nepotrebujes na upgrade iba napichni usb a flashni to!
[QUOTE="kid_rock"]problem nie je z usb iba s active synclerom a ten nepotrebujes na upgrade iba napichni usb a flashni to![/QUOTE]
Prave ze nie. AS som po HR rozchodil, ale ked to chcem flashnut dostanem hlasku " hDev== INVALID_HANDLE_VALUE " a potom " Can not open USB Device ". Pouzivam ScoterRomUpdate-R01.exe. Babo rad ?!
Takze: 1,Na PDA pustim UBOOT ( ScoterUT R55 Magneto) => 2, FlashROM => 3, CE img By USB => 4, Pripojim k PC => 5, Spustim ROM Updater=> 6, OK => 7, dostanem hlasku " hDev== INVALID_HANDLE_VALUE " a potom " Can not open USB Device ".
Mas skusenost s flashovanim cez SD?
